Progress: Tecnomodel 1/24 Ferrari 575 GTC
Alessandro, your work amazes me! I've seen your half cut Enzo and Testarossa...MY GOD! absolutely amazing.
I'm very proud to have you here on our forum!
"Bestest of best" Regards,
Pedro.
P64
Mensagem por P64 »
Petter Escreveu:Alessandro, your work amazes me! I've seen your half cut Enzo and Testarossa...MY GOD! absolutely amazing.
Pedro.
Thank you Pedro !
Alessandro
P64
Mensagem por P64 »
The seat. I gently milled the seat area, not the back, and then I sprayed from long distance some matt black. This is the first time I try this technique and I’m satisfied with it. The back has been covered with BBR carbon decals and clear coated with X-22 Tamiya. Seat belts are a mix of black tape and logos from Modeler’s, red clothed tape from Tesa for the belts paddings and etched seat belts buckles from Scale Production SPE24007.
Alessandro
Muttley
Mensagem por Muttley »
SHOW =D> =D> =D>
Very good!!!
you're doing a great job... :)
Excelent job!
What´s that white stuff in the seat that you milled? Looks like you rubbed some cotton on it...
P64
Mensagem por P64 »
dias Escreveu:Excelent job!
It's the resin which turned white under the milling.
Alessandro :)
Err... sorry. :oops:
I didn´t know since i never worked with a resin kit.
But it really looks like flufy cotton... :D
P64
Mensagem por P64 »
Interiors are nearly completed. Alessandro :)
AMAZING!!!!!
Fantastic job.
Loved the interior with all the wiring. You have the modeling skill called Attention to detail. The wire in the seat is suberb...
Just beutiful!!
P64
Mensagem por P64 »
Hi and thank you for the comments, a very little step ahead. The rear wing is really well done but for the Le Mans version it needs to be shortened of approx. 5 mm each side, so I traced two lines on the wing and cut the two portions. The wing drift and supports have been sprayed with semi-gloss black and covered with BBR carbon decals. Wing element has been primed matt white, painted with gloss white and, after the decals, matt coated with alkyd matt clear.
Have a nice weekend. Alessandro :)
Whooo... what a clean job on that wing.
